Muffler noise.
Old May 6, 2013 | 05:25 AM
yo_marc's Avatar
Here's a couple of thoughts...
The hard top is definitely quieter. The soft top lets a lot more sound through.
Heat shields can rattle and make some ugly sounds at certain RPM's. Sometimes their rattle is heat/temp dependent - meaning they will only rattle when cold or when hot. They probably account for a large portion of ugly exhaust or RPM and load dependent sounds.
I had the head of a pop rivet or maybe a booger from a weld rattling around loose in my factory muffler. Sounded like a high pitch rattle-like squeal at times. Wasn't consistent. Took off exhaust and shook vigorously til it fell out.
Can you describe what your sound is like??
A wheezing factory Honda Civic, or a fart-canned one?
Old May 6, 2013 | 01:05 PM
Warpath's Avatar
Sounds like a honda with a cheap aftermarket muffler. If I had to guess, it sounds like something is loose but, I have no idea what a bad header sounds like so I could not say for sure.
So I put the seats back in (but not the top) and the noise is less apparent. When I took them back out, it was noticeably louder. Guess it is to the dealer I go.
Update: Now it's gone again. I can hear the dealer now, "We can't repliacte your problem." Sigh*
Old May 10, 2013 | 10:48 AM
mike08's Avatar
Originally Posted by Warpath
So I took my hard top off and the back seats out and now my JK sounds like a '92 Honda Civic. The muffler makes an awful noise. Anyone else experience this? Solution without having to go to the stealership?
My heat shield above my muffler fell off and it rattles like crazy. Maybe check that.
Old May 13, 2013 | 02:31 PM
Warpath's Avatar
The dealer was able to replicate it on the first try! The muffler needs replacing. Something inside is making the noise. Kinda pisses me off I have to take a brand new vehicle in for repairs. Let's hope this will not become a trend!
Old Jun 4, 2013 | 08:09 PM
Warpath's Avatar
So it wasn't the muffler. It was replaced and still made the noise. Took it back and now they are saying they can't replicate what I am hearing. BS!!! It's more than annoyance than anything. If it gets worse I'll be taking it back. Maybe I should go to a different dealer and try.
Old Jul 23, 2013 | 08:43 PM
ChrisJF1987's Avatar
I'm having the same issue. Only rattles when I accelerate at start up. After 5-10 min. Gone. Had a crack in the headers but replaced the headers. Still there... Annoying... :-/
Old Jul 23, 2013 | 10:23 PM
BuckLisa's Avatar
Spot welds on the cross pipe and heat shield worn off. I got some pliers and peeled up the heat shield away from pipe. Problem fixed.
Old Aug 5, 2013 | 08:48 PM
Warpath's Avatar
Can you take a picture of where this is?
Old Aug 5, 2013 | 10:28 PM
MojaveJK's Avatar
My heat shield rattles right around the middle between my two diffs somewhere up near the cat I'm guessing could be this, I only now have this sound because I but a new muffler between my axles, idk if this helps at all
