My engine whistles?
This could just be coincidence buy even since I removed my throttle body and cleaned it my engine makes a high pitched whistle at around 2k rpms in second and third gear especially. It doesn't do it in neutral only when driving. It's a 07 3.8 6 speed. I have looked the whole engine over top to bottom with it running and off and I can't figure it out. Any ideas?
Originally Posted by TexasJK07
(Post 3470222)
(Post 3470222)
You can clean it pretty good without taking it off. |
Originally Posted by RoysRig
(Post 3470306)
Something isn't back in it's original place. You've got an air leak.
Could be a bad seal, or a crack in the throttle body from less-than-careful installation. There are specific caution notes in the installation instruction warning about proper torquing. INSTALLATION 1. Install a new intake manifold to throttle body gasket, if replacement was necessary. 2. Install four new j-nuts, if replacement was necessary. CAUTION: The throttle body mounting bolts MUST be torqued to specifications. DO NOT OVER TIGHTEN MOUNTING BOLTS. Over tightening can cause damage to the throttle body, throttle plate, gaskets, bolts and/or the intake manifold. Proper torque of the mounting bolts is critical to normal operation. 3. Install throttle body to intake manifold. 4. Install four bolts and hand tighten. 5. Connect throttle body electrical connector. CAUTION: The throttle body must be torqued in a mandatory torque sequence. Tighten in a criss-cross pattern to specification. 6. Obtain a torque wrench. Tighten mounting bolts (as shown) in a mandatory torque criss-cross pattern sequence to 7.5 N·m (65 in. lbs.). 7. Install clean air hose and tighten clamps to 4 N·m (35 in. lbs.). 8. Connect negative battery cable, tighten nut to 5 N·m (45 in. lbs.). 9. Using the diagnostic scan tool, erase all previous DTC's and perform the ETC Relearn function. |
But what would cause it to only do it at 2k more no less
(Post 3470560)
Y'all said something about a seal being bad which seal would that be and I wish my jeep would whistle Dixie
There is a seal between the throttle body and the intake manifold as described in step 1 of the procedures above.
I have the same thing after cleaning intake, but never removed my throttle body just the intake duct.
Originally Posted by redrocksteve
(Post 3471062)
| All times are GMT -8. The time now is 11:48 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
