MyGig Help
I have a 2010 jku sahara with mygig. I recently noticed that the mygig is not changing from day time colors to night time colors when it is set to auto color change. The daytime color setting is way to bring and kind of blinding while driving at night. I thought it should be switching between the two colors when set to auto but it is always on daytime setting. Has anyone else noticed this? Is there is a fix or an update to the mygig that fixes this issue?
Thanks for the help
Thanks for the help
I figured it out.
fyi for anyone that might have the same thing going on. I had the the dimmer switch on the brightest setting, one before the dome light which must override the auto color change,
once I changed the dimmer switch the mygig changes to the dark colors as it should
