Need HELP! JK won't start!
Old Jul 24, 2015 | 06:34 AM
ChrisMefford's Avatar
Default Need HELP! JK won't start!
I have a manual 2008 JKU. Yesterday morning it started fine twice, then I was leaving a parking lot and it started fine, when I was pulling out it stalled (I think this was my fault, not the jeeps). I restarted it and it stalled again this time on it's own. I tried a third time and it won't turn over at all. Here's where I am at now:
-All electrical systems work(stereo, locks, Windows, etc.)
-Cranks with normal power, just doesn't fire up.
-Tried jumping, rocking, rolling, pulling fuse, lights on/off.
I have tried many times since event and it shows no signs of firing up.
Additional info: I do have a sound system with a 1900W amp running straight to the battery.
Any information or suggestions is highly appreciated. I live 30 Miles from work and need to solve this quick with little funds. Thank you.
Old Jul 25, 2015 | 09:58 AM
ARMTROSS's Avatar
I would clean the Idle Air Control Valve ( IAC )with throttle body/air intake cleaner first see if that helps,
happened to me sometimes it would start then die after 3 seconds or would not start at all
Old Jul 25, 2015 | 11:16 AM
Mark Doiron's Avatar
Is there an unlabeled red light glowing by the fuel gauge? If so, your Sentry security system thinks your key is invalid. Disconnect battery for a minute, reconnect and see if it doesn't start okay.
