Needing advice before dragging it to dealer
Jeep jk all of the sudden won't crank. Seems to stick on the check part of instrument panel as almost all lights stay lit and it won't even try to crank. Won't connect to my scan tool either. Jeep is not still under warranty just looking for advice or place to start.
Did that already. Checked fuses. Grounds. Safety switch in shifter. Starter. Checked all the relays. Load tested battery. Tried a different key. Everything seems to be in order.
