Neutral safety switch (transmission range sensor) Replacement
I'm trying to find a video instructions on how to replace the neutral safety switch (transmission range sensor) ... can anyone point me to installation instructions.
Running the ground cable from the battery -> alternator post hasn't corrected the starting problem. So, I just picked up the the switch this morning ... is was only $32, so its worth seeing if that will correct the the problem.
Appreciate the help!!!
Not sure what has to be done ... other than reading the forums where folks have said it doesn't require getting into the transmission internals. Hoping there is a video out there that walks through it.
It does involve getting into the transmission internals. The first step is to remove the transmission valve body, which has its own set of many steps.
