New Cat from stuck o2 sensor?
Hi!
2013 JK with 84k miles. Got a code for a bad O2 sensor for bank 1 sensor 2. Tried everything under gods green earth to get that thing out and could not. Got the special wrench adapter, PB spray, heat, cut the wire and tried a box wrench, and nothing. I noticed it starting to strip so I stopped. Took it down to the muffler shop this morning to see if they could get it off. Just got a call from them that they cant get it out, cant put in a new bung in , and it would need a new catalytic converter for $1,200.
Is this accurate? Are they any other alternatives?
if a new cat converter is next steps is this something easy to replace. Im moderately handy but it it requires too much effort/time is it worth having a professional do it.
Thanks all
Sad Wrangler Owner
Thanks all
Sad Wrangler Owner
Welcome to JKF, and wow, difficult issue.. if the threads in the bung strip they can be fixed. My good friend/mechanic has the tool to re-thread the bung. You can also go with an Aftermarket CAT (unless your state has specific rules prohibiting) Salvage yards are also a possible.
Here is 1:
Here is 1:
