New toyo tires not fitting well
Old Aug 23, 2014 | 07:54 PM
213jeep's Avatar
Default New toyo tires not fitting well
Hi guys so I bought 4 new toyo tires 35 12.50 18 I noticed that I can't really make. Sharp turns with out the tires hitting .now my 2012 jeep wrangler unlimited has a 2.5inch teraflex budget boost I had bf Goodrich km2 they fit fine and they rubbed on my jeep but not as
bad as the toyo tires I also noticed that there's not enough space in the back tires between the sway bars the new tires are rubbing a lot and it's slowly peeling the thread on my new tires that I paid a s****it load i was thinking about getting some wheel spacers but I heard spacers can damage the tires in the long run any advice would really help I attached the picture of the back right sway bar so u can see where it runs but it's just my back tire that's rubbing and slowly peeling
Old Aug 23, 2014 | 08:02 PM
Ben Todd's Avatar
sounds like you are stuck with spacers or new off-set rims
Old Aug 23, 2014 | 08:04 PM
Jeepstin12's Avatar
Originally Posted by 213jeep
Hi guys so I bought 4 new toyo tires 35 12.50 18 I noticed that I can't really make. Sharp turns with out the tires hitting .now my 2012 jeep wrangler unlimited has a 2.5inch teraflex budget boost I had bf Goodrich km2 they fit fine and they rubbed on my jeep but not as <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=572696"/> bad as the toyo tires I also noticed that there's not enough space in the back tires between the sway bars the new tires are rubbing a lot and it's slowly peeling the thread on my new tires that I paid a s****it load i was thinking about getting some wheel spacers but I heard spacers can damage the tires in the long run any advice would really help I attached the picture of the back right sway bar so u can see where it runs but it's just my back tire that's rubbing and slowly peeling
stock wheels? Only option is to either sell your tires or get spacers for the wheels.
Old Aug 23, 2014 | 08:08 PM
213jeep's Avatar
What's the downside if I get spacers and they are my stock 18 inch rims.
Old Aug 23, 2014 | 08:49 PM
nthinuf's Avatar
Assuming you buy a 'good' set of spacers, remove the goofy retainers on the studs and install the spacers correctly, and check them as part of regular maintenance, there isn't really a difference between running stock rims + spacers or new rims with the same effective backspace. Either one will move the rims/tires out far enough to stop the rubbing. But, if you can't follow the directions and you won't check them occasionally, just buy new rims.
There are plenty of "Are spacers safe" threads on this site to read through, a quick search should find a bunch of them.
Old Aug 24, 2014 | 11:03 PM
213jeep's Avatar
so im a bit confused shouldn't i have cleared the 35's tires with my 2.5 lift i dont understand how my bf Goodrich km2 mt fit well but these toyo tires are rubbing now when you guys say get new wheels what should i get i have stock 18 inch wheels on right now what would be the difference if i get another 18 inch wheel ? sorry newbie here !.
Old Aug 24, 2014 | 11:58 PM
nthinuf's Avatar
Tires from one mfg may be taller/shorter/wider/narrower than the same 'stated' size from another mfg. KM2's are known to run small for their size, while your new tires must be closer to the stated size. If you still have access to the old tires, grab a tape measure and check it out for yourself.
And it isn't just the lift height, it is also clearance with the frame, suspension and steering components, bumpers, pinch seam, whatever else. As the tire gets taller and wider, it should make sense that you need to move it out so it doesn't rub, right? The stock rims have a backspacing of around 6.25". As that number goes down, the rim/tire moves further out of the wheel well and away from the frame/components. If you open either of the threads stuck right to the top of this modified area, you will find some backspace suggestions for various tire sizes. Or, if you look at just about any lift on the market, you should also find the same backspace recommendations.
You noted above that you have a 2.5" TF budget boost right? This is straight from the description for that lift on their website...
Details
The 2.5" TeraFlex budget boost is the most economical lift for the JK Wrangler. The budget boost is designed for JK owners who wish to lift their vehicle without many modifications. The budget boost will increase off-road performance. Several innovative features of the TeraFlex budget boost are found in the exclusive spring retention spacers that do not allow the spring to drop out during extreme articulation. The kit comes with spacers, bumpstops, rear trackbar bracket, rear swaybar links and brakeline ext. hardware. This kit will allow you to run up to a 35" tire (aftermarket wheels with 4.5" backspacing or less are required.) Fits all JK Wranglers including Rubicon and Unlimited.
You went to a taller/wider tire, you kept the stock 6.25" backspace rims, and they are rubbing. No big surprise here. If you want to keep those tires, then you need to move them further out. That will take either a set of wheel spacers, or new rims with less backspace.
Old Aug 26, 2014 | 02:39 PM
213jeep's Avatar
Thanks guys I think I'm getting spidertrax spacers should these be ok for off roading nothing to crazy moderate trails ?
Old Aug 26, 2014 | 02:54 PM
Rob 12B1P's Avatar
Ive done a bunch of trails on spacers. Nothing wrong with them as long as they are properly installed spidertrax type.
Old Aug 26, 2014 | 02:55 PM
jadmt's Avatar
JK-Forum Ambassador
watch King of Hammers lots of guys run them lol
