Newbie Gearing ??
Old May 21, 2008 | 10:21 PM
ben1284's Avatar
Default Newbie Gearing ??
so i have a 08 2 dr. x with the "S"package....how would i know if i have 3.21, 3.73, or 4.10 gear ratios....i've searched and searched for the answer to this ? but could not find an answer.......sorry if this has already been posted..........thanks in advance
Old May 21, 2008 | 10:24 PM
fish's Avatar
From: Apple Valley, California Good ole Mojave Desert.
Was the tow package included when you bought it?
Old May 21, 2008 | 10:26 PM
ben1284's Avatar
nope and it's an auto
Old May 21, 2008 | 10:31 PM
fish's Avatar
hmmm most likely 3.73's . It should say on your window sticker that was there when you bought it. You can visit jeeps website give them your vin # and they will send you a build sheet on your jeep. Several others have did it on here.
hope that helps.
Old May 23, 2008 | 06:37 AM
Originally Posted by KJRubiconWannaBe
You cannot get anything other than 4.10's in a Rubi stock ANY year for JKs.
You have 3.73's.
Incorrect...
The '07 X could be ordered with 4.10s with or without the tow package.
Not that this helps this person, but if someone with an '07 X reads this I don’t want them to be confused.
Old May 23, 2008 | 08:21 AM
Ahhh... I misread your post then...
Then I stand corrected
Old May 23, 2008 | 08:35 AM
jkshed's Avatar
<~~~~~~~~~~ has an 07 4dr X with 4.10's
Old May 23, 2008 | 08:40 AM
RCJeeper's Avatar
To be 100% for, you could raise your rear wheels and rotate your axle. If it takes . . . are you ready for it; 3.21 turns to turn the tire 1 complete rotation, you guessed it, you have 3.21, and obviously the same with any other ratio.
Old May 23, 2008 | 05:20 PM
ronjenx's Avatar
Yes, but if you raise both rear tires, they must both rotate one turn together.
If you raise just one rear tire, the tire must rotate two turns.
This is assuming an open differential.
Old May 23, 2008 | 09:13 PM
ben1284's Avatar
thanks for all the info..i do believe i'm just going to call the dealer b/c there's just too many senarios where it can be diff.....thanks again
