No front signal lights
Old 02-22-2024, 03:59 AM
Starwarsobio's Avatar
Default No front signal lights
Driver side signal bulb burned out. Still worked as a marker light. Installed new bulb and still signal doesn’t work. Pulled bulb from passenger side to see if a socket issue. No change but now when I put passenger bulb back now no signal on that side. New bulbs in both sides. Do you have to reset anything?
Also the rear signals work. Fast of coarse as the front aren’t working
Old 02-23-2024, 10:49 AM
MountainTrails88's Avatar
Pull the bulbs out and inside the plug and look for moisture or green corrosion.
Quick Reply: No front signal lights
