noise in dash
Old Feb 23, 2009 | 06:36 AM
patrol65's Avatar
Default noise in dash
i have a 2007 unlimited rubi. i brought it to the dealer for a sqeeking noise coming from the dash when driven. (on driver's side) they had it for four days and advised they took the dash apart and found the tweeter was loose. drove it home it was fine. sat for a week noise is back . anyone have this issue
Old Feb 23, 2009 | 07:34 AM
saltman's Avatar
I do but mine is on the passenger side. I think the dealer doesn't want to deal with it. They give me the can't reproduce. Which means they either didn't drive it or they don't want to deal with it.
I have taken out all the plastic trim. Stuffed the heater vent with foam and removed the tweeter to try to isolate it but it still does it. Probably one of those things that I will have to deal with. Sucks.
If I really wanted to be an ass about it I would tell them I think it is coming from the airbag area and it is unsafe to drive..... we'll see how it goes next time I take it in.
Old Feb 23, 2009 | 09:37 AM
TINMAN080's Avatar
The cowl vent screen outside under the wipers will vibtate and cause the noise you describe. Several threads have addressed this very problem, try using the forum search feature, perhaps you will find something that will save you a lot of headache.....
Old Feb 23, 2009 | 09:46 AM
saltman's Avatar
That was not the issue with mine. Not even remotely close.
Old Feb 23, 2009 | 11:22 AM
rlabbott's Avatar
Check these threads... lots of 'fixes' here. I had two noises I would have sworn were the dash... it was the cowl vent, the loose fender, and the loose bolts on the windwhield brace, and the loose rollbar bolt on the A pillar.
https://www.jk-forum.com/forums/show...fixes+you%27ve
https://www.jk-forum.com/forums/stock-jk-tech-12/squeaking-dash-noise-cured-3743/
Old Feb 23, 2009 | 12:48 PM
Doc_D's Avatar
Clutch slave cylinder hardline rubbing on the heat shielding. It drove me nuts. I tore my entire dash out before I figured out what it was. Search my posts. I posted a picture of where it rubs and how to check it.
Old Feb 23, 2009 | 04:08 PM
Jmacaws's Avatar
I can hear mine when the jeep is off?
Old Feb 24, 2009 | 03:56 AM
patrol65's Avatar
thanks for all the info! i will let the dealer know whats up when i bring it back. if they dont get it done then i going to have to its driving me crazy
Old Feb 24, 2009 | 04:02 AM
hurstrescue's Avatar
This is something I've been trying to fix also. I've taken the dash apart a couple of times, tried several fixes listed and nothing, still squeaks.
Mine seems to be related to the air conditioning and warmer days. Specifically, on a cold day with the heat either on or off, it does not make the squeak. On warmer days, when the A/C is off, the squeak is there. As soon as I turn the A/C on, the squeak goes away. I'm dreading taking it to the dealer because I'm sure it is going to be a pain in the ass. I will get the "unable to duplicate" routine.
Old Feb 24, 2009 | 10:24 AM
TINMAN080's Avatar
Get a can of spray belt dressing and spray the serpentine belt on both sides. Sometimes your drive belt can wear into a ''groove'' that will cause irritating noise that changes with temperature and accessory usage....
