Noise from underneath....
Today I crawled under my 07 unlimited and found 4 loose bolts on both the exhaust flanges where the exhaust pipes come up and meet the exhaust manifolds. Not easy but tightened them, no more vibration type noises on startup. Craig
i had a very similar issue w/ my JK, i turned out to be a broken tack weld on the heat shield nearest to the catalyc conveter/s. i took into the dealership a couple of weeks ago & htey fixed the issue at no co$t.
are you sure you diddnt just scoop up some pebbles with your skid plate.
the tcase skid plate is very good at holding mud and rocks cause of its high walls.
and since you said it happened after draging it than that would be the opprotunity to catch a few
Check the welds on the crossover exhaust pipe heat shield , one little broke weld makes it sound like you got tranny probs when you gas it. On mine one broke , I pryed it away with a screwdriver, no more noise. A month later, same thing, next weld. Check also the u-bolts that clamp your exhaust together.
