Noisy throw out bearing =new clutch?
Old Jun 30, 2008 | 05:50 PM
goldtr8's Avatar
Default Noisy throw out bearing =new clutch?
I took the Rubi in to the dealer to have them check out a noisy throw out bearing, they said that there is a clutch TSB so they are going to put in a whole clutch assembly.
Some how I dont think that the clutch squeek TSB will fix the throw out bearing noise.
So is the throw out bearing part of the clutch assembly
Old Jun 30, 2008 | 07:01 PM
davidwm71's Avatar
Whenever you change the clutch you should change the throwout bearing. It is a relatively inexpensive part and you are in there already.
Old Jun 30, 2008 | 08:07 PM
Just picked up my 08 unlim rubi from the dealer. Here are the new parts they installed/replaced:
- 53008342 BEARING C
- 53009181-AB BEARING P
- 52104732-AB CLTCH KIT
- 4891685-AA DETECTOR
Driving it home from the dealer it felt really smooth. I had to relearn how to drive stick shift again.
With this new clutch, I am able to chirp the tires a bit on take off. Only bad thing that I noticed
was the smell. I hope it's just the new clutch breaking in, I dunno.
Old Jul 1, 2008 | 02:07 PM
goldtr8's Avatar
Well I got the new clutch but not a new throw out bearing. The service writer was not happy when I asked him what they did because he expected that the tech would have done the clutch TSB and the throwout bearing TSB. He was mad at the tech. So I told him no problem if it makes the noise again they will know what to do. He said my time is should not be wasted.
Looks like I got a keeper service writer so far.
