O/D default
Old Jan 19, 2014 | 05:33 AM
11rubiwannabe's Avatar
Default O/D default
Anyone know if it's possible to swap the O/D DEFAULT so it is disengaged upon startup as opposed having to turn it off manually,I want to only turn it on when I want it on..
Old Jan 19, 2014 | 07:24 AM
ronjenx's Avatar
It's possible with a delayed, momentary relay.
Connect the relay's coil to ignition-switched power, and tap the hot side of the OEM switch through the relay contacts to ground.
A few seconds after you start the engine, the relay points will momentarily close, signaling the pcm to turn off the O/D.
O/D can still be toggled on and off with the OEM switch.
