OEM 17inch wheel specs
I can't seem to find the specifications on the stock, 17 inch wheels. Obviously (duh) 17 inch but couldn't find the width, offset and backspace.
I'm replacing them with 8 inch wide, 0 offset wheels with 275/70 17 tires. That gets me to a 32 inch tire. Trying for the widest tires and nearest to factory ride w/ o lift or need for spacers. Not a lot of off road needs in the FL Keys so more road than 'OFF' down here. Thanks in advance.... just want to confirm I didn't screw up on the wheels with 0 offset.
Here you go:
17x7.5" (width) with 6.25" (back spacing)...
Q: What are all the factory wheels that are available for the JK?
A:Factory wheel type and sizes listed below:
X Standard
Painted Steel - Size 16 x 7.0
X Optional
Painted Cast-Aluminum - Size 16 x 7.0 (2007)
Painted Cast-Aluminum - Size 17 x 7.5 (2008)
Sahara Standard
Sahara Optional
Painted Cast-Aluminum - Size 18 x 7.5
Rubicon Standard
Machined Cast-Aluminum - Size 17 x 7.5
Backspacing on all factory wheels is 6.25
X Standard
X Optional
Sahara Standard
Sahara Optional
Rubicon Standard
Originally Posted by Seabus
So, I'll be fine with the wheel/tire combo w/o the need for spacers. (0 offset, 4 1/2" rear spacing)?
