OEM sterring stabilizer
Old Jul 11, 2009 | 06:39 AM
fftri's Avatar
Default OEM sterring stabilizer
For the second time I developed a severe front end wobble.
Many suggestions/solutions were proposed but it ended up being
a blown steering stabilizer. This was after spending about 1.5 hrs
with Clayton of Clayton Offroad, trying different things.
He went out of his way to find a solution
He called local Jeep dealership and they said that Chrysler is not replacing
the OEM ss with OEMs, they are actually using Ranchos. Defintely a stiffer
feeling in the steering wheel and no more bump induced wobbles.
I decided not to even ask about warranty. I got the Rancho at dealercost
and my JK is modded. Small price to not have any dealership/warranty issues.
Old Jul 11, 2009 | 09:59 AM
AK4Dave's Avatar
I've been running 285/75 16s for quite awhile now, w/ the stock SS. I've never had a problem and run on some pretty bad roads. I'm just surprised that the SS was the only problem you had.
Old Jul 11, 2009 | 01:27 PM
Jeepnboy's Avatar
Good to know there is an aftermarket option that is working. I crushed my ss the second week of having it. I keep thinking about replacing it, but I figure why until I can afford to relocate it. I have been fortunate not to have any significant vibrations (other than the one in the steering shaft the dealer fixed).
Old Jul 11, 2009 | 04:34 PM
quickster47's Avatar
I just did not like the way my steering stabilizer hung down making it vulnerable to offroad obstacles so I purchased a Woods relocation bracket and that moved it up and out of the way so it is now safe.
Carl
Old Jul 12, 2009 | 09:41 AM
bigdeenus's Avatar
My steering stabilizer fell victim to...well...er...me. I was jacking up the Jeep to get a tire rotation in, thought I had my jack lined up with the axle, ended up with a whole lot of hydraulic fluid from the ss on my garage floor!
Old Jul 13, 2009 | 11:34 AM
oldtimejeep's Avatar
Default ss
skyjacker also makes a direct replacement, bigger in size and fits fine. #7003. Morris 4x4 center has them for 43.00
Old Jul 13, 2009 | 12:44 PM
NxtGenCowboy's Avatar
Is replacing one really worth it if every works correctly?
I put the Rubi wheels and tires on my X and was just curious...
Old Jul 13, 2009 | 04:23 PM
4x4jkx's Avatar
OME (Old Man Emu), makes a SS. They are super heavy duty. If you don't want to relocate the SS but want to replace it I suggest the OME SS. It is more expensive but it is heavy duty.
Old Jul 13, 2009 | 05:48 PM
Hellbound13's Avatar
Where can you get that one? Also does anyone know if the rancho is direct replacement?
Old Jul 14, 2009 | 05:13 AM
dcrna's Avatar
I replaced mine with one from Teraflex.............seemed to make it feel more solid.
