Off Roading advice..
Old Jul 26, 2011 | 08:59 AM
tritonman's Avatar
Default Off Roading advice..
I have a stock 2007 JKU Sahara with the 4:10 gears and i know that right off the line they are light off road ready. So my question is...what would be the recommended bare bone basic upgrades to do to increase where i can go off roading, im not talking extreme rock crawling and all that..
Old Jul 26, 2011 | 09:02 AM
JkHauler's Avatar
factory is a pretty capable vehicle. But to increase the mileage, some good All terrain tires or some mud tires would be good and a lift.
Old Jul 26, 2011 | 09:06 AM
jdk's Avatar
jdk
Lift and tires and go with someone with experience and you will be amazed what your jeep will do
Old Jul 26, 2011 | 09:22 AM
08HokieJK's Avatar
I just took my Jeep out last weekend. It is a 2dr X with 3.21 gears, no lift, and the Goodyear SR-A tires. I was shocked at how well it could do. I just put it in 4-lo and it crawled right through the trail. Got to climb a couple rocks too!
To do everything on that trail all I would need is a small lift. Possibly even the TF performance leveling kit or a 2" BB and some tires that are bigger with a better tread pattern.. probably just 33s. But for now I like just having fun stock. Because its cheaper!
Old Jul 26, 2011 | 09:49 AM
PG-JKU's Avatar
You are very lucky to have the 4.10s. If you have good tires, the next thing I would get is a set of front sway bar disconnects.
Old Jul 26, 2011 | 09:53 AM
scotty6336's Avatar
X2. Disconnects will get you a long way with little $$.
Old Jul 26, 2011 | 10:27 AM
MagnumD69's Avatar
Light trails?
4lo & air your tires down below 18psi: point and go.
You'll scrape your skidplates a lot and bottom out the sport shocks... but you'll make it through just about anything.
Bring a friend to help you through the rough spots.
Buy a set of used Rubicon tires and it makes a world of difference off-road. Huge improvement over the SRA's.
Old Jul 26, 2011 | 10:30 AM
JayKay69's Avatar
If I were you I would get swaybar disconnects and rubi take off wheels and tires. You can find rubi take offs on here for cheap
Old Jul 26, 2011 | 10:33 AM
tslewisz's Avatar
Like they said above, mud terrains, front sway bar disco's, 4 low and air down. You will be flat amazed! Then you'll be hooked...and you'll realize why JEEP stands for Just Empty Every Pocket!
Old Jul 26, 2011 | 10:37 AM
davidusr's Avatar
All i've done is change the wheels and added 33's, well, nearly 33's, and I've had no problems. I am looking for a set of QD's. What brand would you guys recommend? Or are they basically all the same?
