Off Roading advice..
Old Jul 26, 2011 | 10:40 AM
tritonman's Avatar
Originally Posted by JkHauler
factory is a pretty capable vehicle. But to increase the mileage, some good All terrain tires or some mud tires would be good and a lift.
Currently it has Firestone Destination A/T's on it from the previous owner and im looking at replacing them with...
Bridgstone Dueler A/T REVO 2
BFGoodwrich Rugged Terrain T/A
Nitto Terra Grappler AT
As far as a lift is concerned i assume a 2" lift would suffice?
I also want to keep this as close to a daily driver as possible with the occasional off road experience.
Coley's Avatar
Originally Posted by scotty6336
X2. Disconnects will get you a long way with little $$.
Bone stock is very capable.
Disconnect.
Air Down. I would take my old stock tires down to 14-15 lbs.
Kick it into 4L when 2H doesn't cut it any more.
I find 4H useless offroad with an automatic... heats up the tranny too much.
Old Jul 26, 2011 | 10:42 AM
tritonman's Avatar
Originally Posted by 08HokieJK
I just took my Jeep out last weekend. It is a 2dr X with 3.21 gears, no lift, and the Goodyear SR-A tires. I was shocked at how well it could do. I just put it in 4-lo and it crawled right through the trail. Got to climb a couple rocks too!
To do everything on that trail all I would need is a small lift. Possibly even the TF performance leveling kit or a 2" BB and some tires that are bigger with a better tread pattern.. probably just 33s. But for now I like just having fun stock. Because its cheaper!
Whats the difference between a leveling kit and a lift?
Old Jul 26, 2011 | 10:43 AM
08HokieJK's Avatar
Originally Posted by davidusr
All i've done is change the wheels and added 33's, well, nearly 33's, and I've had no problems. I am looking for a set of QD's. What brand would you guys recommend? Or are they basically all the same?
I have seen that the JKS ones are nice. If I remember right they are about $100 at Northridge.. Not too bad
Old Jul 26, 2011 | 10:44 AM
tritonman's Avatar
Originally Posted by PG-JKU
You are very lucky to have the 4.10s. If you have good tires, the next thing I would get is a set of front sway bar disconnects.
I guess the person before me got the towing package which upgrades it to the 4:10s which i dont understand what the benefit is, i just see that people wish they had them.
I assume by using sway bar disconnects that allows me more flex to keep more tire on the ground?
Old Jul 26, 2011 | 10:48 AM
dillUSMC's Avatar
yea lower gears are good for when you get bigger tires like 35's, by the way if you ever regear get 5.13's trust me
Old Jul 26, 2011 | 10:53 AM
08HokieJK's Avatar
A leveling kit is just a small budget boost (spacers on top of the coils) Usually 1-1.5". It lifts the Jeep a little but it also levels the front to the rear, which is good for heavy bumpers and winches. A lift kit can be a budget boost (up to about 2-2.5") or replace the coils. The pricing from low to high is leveling kit, budget boost, coil lift.
Someone with more experience is welcome to correct me or elaborate but I think that is about right.
Old Jul 26, 2011 | 10:54 AM
PG-JKU's Avatar
JKS Quicker Discos. Solidly built and pretty easy to remove and install.
Old Jul 26, 2011 | 11:02 AM
tritonman's Avatar
Does either one change the way it performs as a daily driver?
Old Jul 26, 2011 | 11:06 AM
JkHauler's Avatar
You would love BDS QD's
