Oil Consumption....
Was wondering how much oil your JK's 3.8 is using? Approx how many miles before you notice you're a quart low? Kinda would like to get an average here.
Thanks......
Thanks......
about a quart every 1200 miles. For the first 32000 miles I didn't consume a drop ... Still trying to sort it out where it's going.
Thanks.....
See, that's pretty much why I've asked. For the last couple oil changes my rig has gone down a quart before the 6k synth oil change time....a little over 5k. I posted another thread about this because I am running Royal Purple, and wanted to know if anybody else has noticed the same. One guy, can't remember who, said he had the same happen with RP, and when he switched to Mobil 1, he didn't use any oil. I guess it doesn't matter as I've already decided that I will not use RP anymore. When I first bought it I got it for around $7. a quart....by the case. Last time they charged me $10. So I feel it's not worth it anymore. I just really wanted to know what kind of oil consumption people were getting using ANY type of oil, so I could get an idea of what is normal or not.
Thanks.....
Thanks.....
We'll see how it goes now that I'm on my second change of synth, for the record I'm using Pennzoil Platinum. Seems to be pretty good stuff for the money as well. I also run the stock Mopar filter, which has been good in the anti-drainback valve category so far.
Changed to RP (5-20) at 6000, check every am, run 10,000 between changes, now have 46,000---use maybe 1/2 quart between changes--very happy with RP--also have Power One permanent filter installed when I changed to RP--installed an oil pressure and temp gauge using a filter collar at same time--everything runs well
-- C.R. Wood
-- C.R. Wood
