Oil leak diagnosis
Oil leak diagnosis
I've got the drip! Almost daily I'm seeing a few drops of oil on the garage floor. Check out the pic and let me know what could be causing this leak. Jk gurus chime in please
I would look around the whole motor for a place where its visibly dripping down
I spilled a LOT of oil on the engine about 10 days ago. I thought I got it cleaned up. I don't see any excessive visible oil on the engine now. Could it still be dripping down from the spill 10 days ago? I didn't have any drips before my oil change.
The most important thing is to keep checking the oil level in the engine.
Since you just changed the oil its worth noting...did you make sure the gasket on the old filter came off? 2 gaskets will definitely cause a leak. If it didn't leak before your oil change, it would be the first place I'd check
Edit: it says you spilled oil on the motor...i assumed it was during an oil change, but now I'm unsure if you were actually changing the oil or just happened to spill oil while doing something else.
