Originally Posted by SDJK
(Post 938633)
Mine was leaking there also-I thought it was the rear main and it turned out to be an intake gasket-dealer repaired and no more leaks:thumbsup:
Originally Posted by Lorrel
(Post 938492)
Thanks for pointing that out. I would have never thought a leak up front would so up in the rear.
My vote is the timing chain cove. My leaked and was replaced at the dealership. FREE
Mine seems to be just around the lowest bolt on the bolthead side. Again, not wet or dripping, just kinda dirty and when I wipe it with my finger it's black like oil. Hopefully just needs to be retorqued back down. Anyone know the torque specs on these?
Originally Posted by MELONHED
(Post 942332)
Retorquing the bell housing bolt won't do anything for you as far as preventing leakage. |
Originally Posted by ronjenx
(Post 942543)
Earlier you said "I've got the same lookin thing". So I take it your leak looks like it is at the bell housing.
Mine looks similar to that I have the 6 speed and just had the intake manifold gasket replaced but looks like it is still leaking out of the bell housing some not really dripping just wet with oil even after wiping off a day or two later it will return dealer doesnt want to do anything about it they said it is residual from the intake gasket well that was 4500 miles ago the fixed it and when I changed my oil it was a qt low with 4000 on the oil I think it may be burning it too but not seeing any smoke though. I will wait and see what this oil change cycle shows.
I have had to replace a couple rear main seals on these already. When the rear main leaks oil fills up in the bell housing and continuous to leak there unless its cleaned out.
