Oil sensor
Old Dec 12, 2015 | 07:37 AM
fredski's Avatar
Vet Army
Default Oil sensor
Oil pressure reads 99 pounds ,tec said sensor needs to be replaced, must order part. Said they need to pull manifold to replace! Is that true. Preferred not to have that done. Under warranty but still sounds kinda out of line?
Old Dec 12, 2015 | 09:49 AM
jtphoto JK's Avatar
If it's first gen 3.6 , yes the oil filter, oil cooler, assembly must be replaced if the valve is faulty or broken.
Old Dec 12, 2015 | 12:02 PM
tjkamp's Avatar
If it is the oil pressure sensor/switch, then yes, on the 3.6 both the upper and lower intake manifolds must be removed to access the sensor, it is mounted in the bottom of the lifter valley (I don't know what else to call that even if it is an OHC engine).
When mine went out it gave a check engine code. Did yours?
Old Dec 12, 2015 | 06:22 PM
fredski's Avatar
Vet Army
Default Oil
Engine light came on and digital gage read 99 pounds, just went thru long large muddy and wet trail,!
