Older Rubi rails fitting 2012 JKU Sport
Old Jul 1, 2012 | 10:28 PM
RedRockJeeper's Avatar
Default Older Rubi rails fitting 2012 JKU Sport
Have a question, may seem stupid, but here goes. Is there something different about the 2012 bodywise that keeps previous year Rubi rails from fitting. Went to pick up rails from forum member here in Sacto and i could not get the brackets to line up. If I am wrong here correct me please...the rails mount at the body mounts and on the lip of the body work, right? Could not get the body mounts to line up correctly no matter which way I turned them or what side I tried to line them up. Granted I am not an auto mechanic but I am pretty proficient at most of it. Did I screw up or someone have some info for me?
Old Jul 1, 2012 | 10:32 PM
Sporticon's Avatar
I put some from a 2008 on my 2012 no issues, my recommendation is to put all bolts in loosely at first just enough to hold the rail up in place and then alternate tightening them all down til they are all tight.
Old Jul 1, 2012 | 11:41 PM
So am I right about how they attach? If they attach to the body mounts, then bolt in to the holes in the body skirt, I could not get them to line up at the body mounts.
Old Jul 2, 2012 | 03:26 AM
HELLBENDER-JK's Avatar
I hope this isn't just a right side / left side issue. I got a set from a 07 and it fit my 12 no problem
Old Jul 2, 2012 | 05:13 AM
Sporticon's Avatar
I put the end two bolts in first loosely then the middle. It does help if you have another set of hands to help. I remember on one side I had to loosen the ones I put down tight to get the last one in.
It should fit I have never heard of them not.
Old Jul 2, 2012 | 06:10 AM
brian361us's Avatar
From: West Jefferson, North Carolina, United States
They are left and right side. I just took the set off my 2007 jku and put them on my 2012 jku.
Old Jul 2, 2012 | 05:58 PM
ok must be my temporary insanity then. Feeling kind of stoooopid right now. Here's hoping he hasnt sold them.
Old Jul 2, 2012 | 06:52 PM
MikekiM's Avatar
They don't attach to the body mounts. There are holes under the body that are covered with black tape. Remove the tape, insert the clips flat side down. Bolt them up. Not only with the older JKU rails fit the new bodies, the JKU rails will fit on the two door if you trim them. Mounting points are identical.
Old Jul 2, 2012 | 08:16 PM
Sporticon's Avatar
Yeah what he said, I forgot about that black tape part.
Old Jul 3, 2012 | 04:09 AM
brian361us's Avatar
My 2012 didn't use the clips had holes drilled and tapped already on the underside.
