An other wierd noise when turning
Old Jul 15, 2008 | 06:21 AM
jkkat's Avatar
Default An other wierd noise when turning
Hi Guys and Girls,
Before putting on my Pro Comp X terrain 35's i had this wierd noise comming from the left front wheel that sounds like a door creeking when i turned the stearing wheel eather way but it was not constant. Now after putting on other 600 miles with this noise and doing the WA state Trail Jamboree this past weekend, I started going through everything and had a friend turning the wheel and found the loose left front wheel bearing. Jacked it up and the left front almost flops back and forth from side to side and the right front is not as bad but it moves as well.
Has anybody else had a problem with there front wheel bearing?
Kat
Old Jul 15, 2008 | 08:04 PM
jkkat's Avatar
bump because
