Over tightening of lug nuts
Old Oct 11, 2011 | 06:47 PM
Patchules's Avatar
Originally Posted by ronjenx
I always use a torque wrench to tighten; and NEVER use a torque wrench to loosen anything.
I was curious as to just how much they had overcranked. Torque wrenches are quite unreliable at loosening because the nut does not turn smoothly. In this case I did not continue past the setting on the wrench but increased the setting in increments of 20 ft-lbs so the wrench was at no time forced beyond its setting. Perfectly safe when done this way, the wrench does not know the difference otherwise it could not be used for left hand thread tightening.
Old Oct 11, 2011 | 06:51 PM
ronjenx's Avatar
Not to argue, but the wrench does know the difference when the nut breaks loose.
Standard training and practice is to never use a torque wrench to loosen.
Old Oct 11, 2011 | 06:59 PM
Patchules's Avatar
Yes, there is a risk of damage to the wrench, particularly the click type with the spring and toggle inside. The bending beam type is pretty sturdy however.
Old Oct 11, 2011 | 07:09 PM
f2fast4u's Avatar
Not on the lug nuts. They depend on the threads being clean and dry to have the proper torque, and remain tight.
(That includes the nut/wheel contact surfaces, too.)
We will agree to disagree on that one, that's fine. Millions of mile to backup what I'm saying, never had a lug nut back off in my life. Also, no one would ever use thread locker either...
Old Oct 11, 2011 | 07:18 PM
ronjenx's Avatar
Yeah, I wasn't criticizing, just countering with what the book says. People can use both points to make their own decision.
Old Oct 11, 2011 | 07:59 PM
f2fast4u's Avatar
I understand and didn't take it that way.
Honestly on the race cars with ARP hardware it's not an issue but with the corporate world those studs went to a cheaper grade of steel in the past decade (can you say they saved about $5, ka-ching) and binding is a huge issue. I've personally snapped off at least a half dozen studs that just seized with the nut coming half way off. Now, we chase all new or aftermarket lugs first before installation and then hit the studs with a tad of antiseize. Never had an issue anymore on factory studs.
Old Oct 11, 2011 | 08:08 PM
ronjenx's Avatar
I've never had a problem, either. I think the key for me has been regular tire rotation. It keeps the nuts from seizing, just by being removed and cleaned periodically.
Old Oct 11, 2011 | 08:19 PM
jeeeep's Avatar
I had my wheels and tires instsalled at Discount Tire - their air wrench is set to 80 Ft lbs then they use torque wrench for final torque.
Old Oct 11, 2011 | 08:25 PM
ronjenx's Avatar
Originally Posted by jeeeep
I had my wheels and tires installed at Discount Tire - their air wrench is set to 80 Ft lbs then they use torque wrench for final torque.
I asked the guy at the tire shop if he was going to use a torque wrench when he reinstalled my wheels. He said he would.
He ran the nuts down with a gun he said was set low. Then used the torque wrench. I mentioned I noticed the nuts didn't move before the torque wrench clicked. He said "Yeah, so?"
Old Oct 11, 2011 | 08:57 PM
ronjenx's Avatar
Originally Posted by DeReK_AgIn
Im still a newb and this may be a dumb question, but what is a good torque? when i got my lift done they told me they torqued them to 110 (going to back them off and check now to be sure) but is that too much?
The factory service manual calls for the lug nuts to be dry torqued to:
[TABLE]
[TR]
[TD="bgcolor: white"]Lug Nut 1/2 X 20 with 60° Cone
[/TD]
[/TD]
[TD="bgcolor: white"]92-132 ft/lbs
[/TD]
[/TR]
[/TABLE]
The owners manual says 95 ft/lbs.
