overheating problems
Old Oct 12, 2010 | 10:51 AM
centerfieldr162's Avatar
Default overheating problems
Hey guys just recently my Jeep has started overheating. It's never had this problem before but I was sitting in a car wash and the warning light came on and the warning started sounding. It hasn't stopped and it is the worst when I'm stopped at a red light or something with the engine still running. It will overheat but when I start going it is fine. And the air conditioner won't blow cold air anymore. Wtf is going on??
Old Oct 12, 2010 | 11:03 AM
WhiskyPirate's Avatar
sounds like an issue with the fan to me... is it coming on? any mud stuck up in the radiator?
Old Oct 12, 2010 | 12:05 PM
petro's Avatar
Assuming your fan is coming on, your rad is plugged. The added breeze you get when driving helps and as soon as you stop at a light/idle, temp starts to rise. Crap gets inbetween the fins and even if it looks clean on the outside front/back, trust me, it's not. This has happened to me. You need to remove the fan and cowl (not hard) and get a hose in there to flush everything out, that's the only way to really get it clean
Old Oct 12, 2010 | 12:13 PM
grim_creation's Avatar
just get yourself a squirt gun and blast out in between the fins then when they are good and clean check the fan.. if running great. if not.. well check the fan first on a different power source with different connectors, if the fan works... time to track yourself down some wiring issues. if not. time to get yourself a new fan.
Old Oct 12, 2010 | 12:15 PM
ASTE25's Avatar
Check your radiator cooling fan. It sounds like it is not working. If it was a plugged radiator, then that would not cause the air conditioner not to cool. You describe the classic symptoms of an inoperative cooling fan.
Old Oct 12, 2010 | 12:21 PM
Pluke the 2's Avatar
Ya know, I was driving for about five hours and my Air Conditioner shut off on me out in the desert. It was close to 120F in death valley and it sucked.
When I got home I installed an aftermarket auxiliary cooler and it hasn't happened since.
Old Oct 12, 2010 | 12:26 PM
brobbins67's Avatar
My fan is being replaced right now. It would come on but was very slow and sounded terrible. I wonder if all this mud had anything to do with it?
Sent from my HERO200 using Tapatalk
