P0000?
Old May 24, 2008 | 12:09 AM
aldaman's Avatar
Default P0000?
I updated my Max Energy Programmer via the intenet I was going to re-install the program on my JK. When I hooked up the programmer a P0000 DTC came up. I tried searching thru the DTC thread, but only found p0016 and higher. Does anyone know what this code means and should I be worried...Please advise, thanks..
Old May 24, 2008 | 12:13 AM
aldaman's Avatar
Found this on a previous search...Is this correct, can anyone verify...Thanks again..
Originally Posted by AZJeeper
OBD-II follows the ISO 9141-2 standard. As near as I can tell, P0000 means either "End of DTC list" or "No Trouble Code" - both of which are meaningless.
Old May 25, 2008 | 12:18 PM
JulietKilo's Avatar
Yeah I got the same thing when I FIRST installed the Hypertech. It doenst do it now. I play with that thing all the time. I love it!
Old May 25, 2008 | 05:06 PM
aldaman's Avatar
Thanks...I may be doing the same thing from time to time (every 2mos)...Just to see if there are any new updates that needs to be downloaded..
Old May 25, 2008 | 05:10 PM
tambil68's Avatar
Same here. The first time I ran my Hypertech it returned no errors. The second time it returned the P0000 also, all I could find using Google is that is either "no error" or end of list.
Either way I don't and haven't had any problems with the JK.. so for me.. No Worries.
Hope this helps ya.
Old May 25, 2008 | 06:12 PM
JulietKilo's Avatar
Yeah, you will have to turn your Jeep back to all stock settings, plug it into the computer update to the newest software which is 1.1.7.3 and the latest firmware (dont remember the number) Then reinstall it on your Jeep. It works so much better now.
EDIT: When I say better, there are no errors, things work faster, there are less steps and the Jeep even feels like it runs smoother and stronger! They are always tweaking our computers to get more power ya know, I need to find a dyno around here.
