Front wipers not working properly
Hi there. My 2013 Wrangler 4-door front wipers stopped working properly. At any intermittent setting they go at the "normal" speed, and if I turn them off with the wiper switch in any position the wipers stop wherever they are in the cycle, not going to the "park" position. The normal and high speed settings in the switch are OK but it still does not park when stopped.
I replaced the steering column wiper switch assembly (replacement assembly from Amazon) and it still has the same issue. I am wondering what to try and replace next. Is there just the motor itself or I also read about a possible module for the wipers in the CAN bus system? Is that a thing in the 2013 JK?
Thanks
Thanks
