Pitman Arm Nut size
Old Feb 24, 2009 | 09:01 AM
asjackman's Avatar
Default Pitman Arm Nut size
What's the size nut on the pitman arm? Some say 33mm, some say 34mm, which is it?
Old Feb 24, 2009 | 09:17 AM
SiliconTi's Avatar
HAHA! I just had this issue! Mine is an '08 Rubi. I used a six-point 34mm socket and it worked, but was too big (would have slipped if it was 12-point). I'd say 33mm.
Old Feb 24, 2009 | 11:31 AM
asjackman's Avatar
Where'd you find the socket?
Old Mar 8, 2009 | 06:33 PM
SiliconTi's Avatar
Borrowed it from a local repair shop. I actually had an appointment for them to do it, but the guy saw the Jeep, said "you are obviously mechanically inclined" and handed me the socket and pitman arm puller. He was running behind. I gladly borrowed them and gave him a $20 as thanks. That socket was impossible to find, and I was going to just have the dealer do it.
Old Mar 8, 2009 | 06:50 PM
odin725's Avatar
I bought mine from a local auto parts store or hardware store. cant remember which one. the brand is Great Neck.I would think you should be able to find one. it was around 10 Bucks.
Old Mar 8, 2009 | 07:34 PM
Hellbound13's Avatar
Why did you guys need to remove the pitman arm nut for? Putting a lowered one in?
Old Mar 8, 2009 | 07:40 PM
odin725's Avatar
That's what i did. Put a drop pitman, then took the nut off to put on a sector shaft brace.
also not sure but i would bet you could also use a 1" 5/16 socket on the nut.
Old Mar 8, 2009 | 07:43 PM
What does the sector shaft brace do?
Old Mar 8, 2009 | 07:50 PM
odin725's Avatar
when you have a drop pitman arm it helps keep the shaft coming out of the steering box from getting bent or messed up.basiclly helps keep it from moving side to side.
I made mine but here's a look at one http://www.offroadevolution.com/stor...?prod=EVO-1015
