Please help!!
Old Jan 31, 2012 | 06:52 AM
Ryan0260's Avatar
Originally Posted by jeepmojo
i had similar problems with other vehicles that was caused by a bad battery cable if its faulty it can cause what seems to be intermitant problems with lights on off starts stalls has you chasing a wild goose sand paper both negitive cable and post
X2. Before you do anything else check all your wires and grounds, exspecially both ends of the battery ground
Old Jan 31, 2012 | 11:47 AM
MagnumD69's Avatar
Default Electrical Gremlins are often caused by bad grounds or wiring shorts
I went through a lot to narrow down and eliminate my electrical woes... maybe this will help:
https://www.jk-forum.com/forums/show...tery-terminals
A bad wire was causing electricity to arc, melting the wire due to the higher resistance. The wiring harness was under $200.
All said and done with a new alternator, battery, labor, and new harness cost me about $1000 to fix. Make sure they check this part, first.
