Please help
Old May 5, 2021 | 08:13 AM
JeepGirl220's Avatar
Default Please help
I have a 07 Jeep Wrangler Sahara Unlimited and I just purchased this vehicle and yet to get to enjoy it. These two irritating lights keep coming on electronic throttle and traction control and it causes me to lose power. I changed the throttle body, drive train module, crankshaft sensor and still coming on 2nd month and still haven’t drove it more than 3days. I’m ready to run it into a tree.
Old May 5, 2021 | 11:11 AM
Sv_dude's Avatar
5 Year Member
Loved
Community Favorite
What cel codes are you getting?
Old May 5, 2021 | 12:21 PM
resharp001's Avatar
Loved
Community Favorite
Quick guess here is an ABS sensor throwing codes in ABS and Tranny modules. You need a reader that can scan those modules and see what the specific codes are. Something like the Jscan app and BT dongle work great as a cheap setup, but many others are out there. Since I don't use their service, I'm not sure if the local parts stores read more than basic OBDII codes, or if they can give you the codes to the deeper modules.
Old May 6, 2021 | 07:27 AM
JonesboroJeep's Avatar
Do this for the Throttle which should help someThrottle/pedal calibration procedure. I've seen this same procedure in multiple forum posts, but have never seen the original source of this procedure referenced. I'm guessing it's from some non-publicly-accessible technical service documentation:
throttle Calibration Procedure:
Throttle calibration can substantially improve throttle responsiveness over "factory standard." Many people notice what appears to be sluggish throttle response or a "dead area" at initial accelerator depression. Throttle calibration can take care of these.
1) Insert ignition key and turn to "ON" (not start).
2) Wait for all idiot lights to go out. Check Engine Light may remain on.
3) Slowly depress the accelerator pedal all the way to the floor.
4) Slowly release the accelerator pedal until it's all the way back up.
5) Turn the ignition key to "OFF".
6) Start the engine.
Most drivers notice an immediate change in throttle response, but depending on your driving style, you may need to repeat this procedure periodically due to the computer's adaptive programming. You likely need to repeat this procedure any time the battery is disconnected.
From <https://www.wranglerforum.com/thread...ration.888666/>
Old May 6, 2021 | 07:30 AM
The traction control issue is usually tied to wheel sensors. Until you get that fixed, here is a work around. If it pops up and goes into safe mode, pull over stop the car, open the door, close and re-start. The light should go off or may take a few minutes. Immediately turn off traction control down by the gear shift. The rear wheel sensors go bad first usually and they are easy to replace. Quadratec has a good list of them and instructions.
2007-2018 Jeep Wrangler JK Sensors | Quadratec
If it is your rear wheel sensor and you drive a JK this is what I bought. Crown Automotive 52125003AB Rear Wheel Speed Sensor for 07-18 Jeep Wrangler JK & 08-12 Liberty KK | Quadratec
