Please help me!!!!
Ive had my 08 wrangler x jk for about 4 months now and I just got a 5" short arm fabtech lift installed with 37's and J.E. Reel front and rear driveshafts. After driving it around the first day i noticed the check engine light had come on. I went to Autozone and got them to hook it up and see what code it was reading. It came back p1775 Solenoid Switch Valve Latched In Tcc Position. I have no idea what this means and any help once so ever would be much appreciated.
Thanks
Thanks
CHECKING SYMPTOMS AND POSSIBLE CAUSES
LOW BATTERY VOLTAGE CAUSING SYMPTOM
OTHER CODES PRESENT
TRANS CTRL RELAY OUTPUT CKT SHRT TO L-R PRES SW SENSE CKT
TCM L-R PRESSURE SWITCH SENSE INPUT
TCM L-R PRESSURE SWITCH STATE READS OPEN
TRANSMISSION SOLENOID PACK
INTERMITTENT CODE P1775
VALVE BODY ENGINE IDLE TOO HIGH
VALVE BODY SOLENOID SWITCH STUCK IN LOCK-U
I would check all of the connections (electrical) going to the transmission. Maybe they unhooked something while installing the lift causing a code. and check the trans relays/fuses if there are any.
this probably doesnt answer your question but something to check before you take your Jeep in for service and they charge you for something that the people that put on the lift did.
just my 2 cents...
OTHER CODES PRESENT
just my 2 cents...
thanks for the responses...i took it down to my dealership and they are going to fix it next week with no questions asked. They didnt even question whether putting on my lift could of caused this problem or not.
Thanks
Thanks
Next time you might be able to spare yourself the trip to Autozone or elsewhere to have your JK scanned, this thread has helped me alot:
https://www.jk-forum.com/forums/stock-jk-tech-12/jk-computer-diagnostic-codes-21769/
