Is it possible to delete the exhaust crossover without problems?
Old Sep 10, 2012 | 03:28 PM
chubbchubb's Avatar
Default Is it possible to delete the exhaust crossover without problems?
I noticed that the exhaust crossover makes an automatic transmission fluid change nearly impossible. With it being so close to the pan I'm sure doesn't help either....so I figure would it be possible to just delete it or move it?
Old Sep 10, 2012 | 03:52 PM
BigSteve's Avatar
You mean delete the y pipe?
Old Sep 10, 2012 | 04:01 PM
ronjenx's Avatar
If you don't get the answer you are looking for, here is an alternative that makes removing the pan a lot easier.
The wrench and bolts pictured below make the hard-to-get-to bolts very easy to get to.
As you can see, they remove the requirement to have a straight on shot. I have installed these on some of the JKs I have done fluid changes on.
Another thing I have installed on people's JKs is a drain plug in the pan to make the next fluid/filter change much easier.
Old Sep 11, 2012 | 04:56 AM
chubbchubb's Avatar
Thanks RONJENX...perfect solution to the problem! Much cheaper than re-routing exhaust system. Would you by chance have the bolt replacement dimensions you used &/or ordering info?
Old Sep 11, 2012 | 06:53 AM
ronjenx's Avatar
I don't recall the size. I took an original bolt to the hardware store and picked 3 or 4 allen head screws of the same size, plus a thread to allow a washer under the head.
Old Sep 11, 2012 | 10:32 AM
fivenote's Avatar
Ron... those are some cool ideas - I always pay attention when I see your posts. One thing... I'm assuming the drain plug doesn't help with changing the filter, right?
Old Sep 12, 2012 | 07:34 PM
TINMAN080's Avatar
No help with the filter other than enabling you to drop the pan EMPTY rather than having tranny fluid running all over your arms.
