power door lock problem
Old Oct 11, 2013 | 08:12 AM
Rbzak's Avatar
Ok I know there are alot threads on here about power door lock. But none of them fit my problem.
08 jku Sahara 73k miles
My right rear door lock will not lock or unlock with the switch or the fob. It moves but not enough to make it work like it is suppose to. I have check the plug and voltage it looks good. I have also taken the door panel off and the whole assembly out and check it. I didnt open the assembly up.
Anyone else have that problem. If so how did u fix it.
Old Oct 11, 2013 | 08:49 AM
SKTN Rubi's Avatar
This is why I no longer regret settling for the used rubicon with no power windows/locks. Best decision, taken enough flack from people commenting about it being a new vehicle (Rubicam at that) and not even having power windows/locks. Well things do break, especially when said thing is exposed to the type of off-roading these Jks or capable of. Also being stuck with a dead battery and the windows down. No thanks.
Any hoo hopefully someone will chime in. Probably just need a new actuator by the sounds of it. Might of got wet, little seized now. Oil my help?
Old Oct 11, 2013 | 08:55 AM
Rbzak's Avatar
Yeah thats whats I was thinking. A new actuator. But didnt want to buy it if this one is fixable. I might try some oil. It cant get any worst. Right?
Old Oct 11, 2013 | 09:29 AM
Jiblet's Avatar
Does it work OK when you use the key in the cylinder? I'd look over the connecting rods for obstruction or slipping.
The actuators aren't too expensive, maybe in the $60-70 range. Haven't heard of many (any) wearing out.
Old Oct 11, 2013 | 09:50 AM
Rbzak's Avatar
It works fine when manually lock and unlock. But not using power.
Old Oct 11, 2013 | 11:39 AM
Jiblet's Avatar
If nothing is dragging or catching then it must just be fading away.
You could disconnect. Reconnect the wire harness. Check for corrosion there.
You could try holding it close enough to the other side to plug in and test it from that power plug.
In other words, remove the other rear door then have helpers position the questionable door close enough to plug in there. See if you notice any change. That could rule out body wiring etc.
Just brainstorming. Good luck.
Old Oct 11, 2013 | 08:13 PM
Surf City Dan's Avatar
This is why I no longer regret settling for the used rubicon with no power windows/locks. Best decision, taken enough flack from people commenting about it being a new vehicle (Rubicam at that) and not even having power windows/locks. Well things do break, especially when said thing is exposed to the type of off-roading these Jks or capable of. Also being stuck with a dead battery and the windows down. No thanks. Any hoo hopefully someone will chime in. Probably just need a new actuator by the sounds of it. Might of got wet, little seized now. Oil my help?
Really!! You take this stance on power door locks or windows? Just like you said, things do break. Air conditioning, power steering, navigation, and so on. Can you honestly say if you were in the market for a JK and both were the same price but one had power door locks and windows you would take the one with a window crank..
Old Oct 12, 2013 | 06:35 AM
Neral22's Avatar
If the key works fine, then the cables should be fine. I would check the power cords for a loose connection, especially if youve taken the doors off. Good luck.
Old Oct 12, 2013 | 03:33 PM
JeepaRoo's Avatar
my dad special ordered his JK purposely with NOTHING on it...
he got A/C and a CD player... thats it... he says power stuff breaks to much.
me on the other hand gets my JK's pretty Loaded... if they made sahara with black plastic fender flares id probably always get loaded sahara..
-Christopher
Old Oct 13, 2013 | 02:46 PM
Originally Posted by JeepaRoo
my dad special ordered his JK purposely with NOTHING on it... he got A/C and a CD player... thats it... he says power stuff breaks to much. me on the other hand gets my JK's pretty Loaded... if they made sahara with black plastic fender flares id probably always get loaded sahara.. -Christopher
Sounds good!!
