Power door locks ??
Is there a way to turn off the automatic door locks when you start moving. These things really get on my nerves. Everytime I try to open my tail gate I have to unlock the door's.
My JK locks at about 10 mph, but then, they all unlock when I open the door to get out.
This is from an '08 manual. See if it works on your '07.
Automatic Door Locks Programming
The Automatic Door Locks feature can be enabled or
disabled as follows:
1. Close all doors and place the key in the ignition.
2. Cycle the ignition switch between LOCK and ON and
then back to LOCK 4 times ending up in the LOCK
position.
3. Depress the power door lock switch to lock the doors.
4. A single chime will indicate the completion of the
programming.
5. Repeat these steps if you want to return this feature to
its previous setting.
Automatic Unlock Doors on Exit Programming
The Automatic Unlock Doors On Exit feature can be
enabled or disabled as follows:
position.
3. Depress the power door unlock switch to unlock the
doors.
programming.
position.
programming.
position.
doors.
programming.
position.
programming.
position.
doors.
programming.
position.
programming.
position.
doors.
programming.
Make sure you are going all of the way to on. The switch has four positions in this order: Lock, Unlock, On, Start. You will know you are there if the radio starts up.
