power loss question
Old Feb 21, 2013 | 03:10 PM
HBC's Avatar
HBC
Default power loss question
I have an 07 with 97k miles. The last couple of weeks when I first start it (after it's been sitting a couple of hours) it hesitates and loses almost all power. After I get it up to speed it doesn't do it again. The abs light also comes on for a minute. It's not the fuel quality. What should I look for?
Old Feb 21, 2013 | 06:32 PM
Mr.T's Avatar
Community Favorite
Suggest finding someone good at trouble-shooting with a scan tool (not just a code reader) to monitor/record various engine parameters while driving, when it's having the problem.
Old Feb 21, 2013 | 07:40 PM
shockwaveaz's Avatar
Did you do the dance to check for any codes? Does it feel like it is in limp mode from the computer or an engine problem?
What kind of transmission do you have?
Sent from my SPH-L900 using Tapatalk 2
Old Feb 22, 2013 | 05:11 AM
HBC's Avatar
HBC
Will do! Thanks for the advice!
Old Feb 22, 2013 | 05:16 AM
HBC's Avatar
HBC
Haven't checked the codes, yet. It sounds almost like 'grinding' as it's losing all power. It feels like it's flooded, or has water in the fuel. My way of pushing through it so far has been to 'floor it'. It slowly builds up speed and then takes off fast.
I was thinking maybe a fuel filter, vacuum leak, or restricted air flow. Any thoughts?
Old Feb 22, 2013 | 06:37 AM
efan450's Avatar
Vacuum leak will trip a code almost instantly. check your oil! Make sure its not seizing up from low oil! But i think you had a good suggestion...with it being a few years old and getting up there in mileage..the fuel filter may be clogging up, you can try tapping on it with a screwdriver handle and see if it helps with the lack of power, maybe it will help pinpoint the problem, but the filter clogging won't set a code and it would feel like its flooding out so to speak...could the grinding be really loud spark knock? Have you ran a tank of 93 through it just to see if the noise goes away. Your knock sensors could pull so much timing due to knocking that you loose power
Old Feb 22, 2013 | 07:05 AM
yo_marc's Avatar
My first thought is a wheel speed sensor -- Of if your steering is drastically out of whack, ESP kicking in.
Does the grind come from under the hood? A muffled blender-like noise? If so, that is probably the ABS pump.
When ABS/ESP kicks in, the ECU pulls power out of the motor - which makes it feel like it falls on it's face. The traction or ESP light (whatever it is) will flash when it's activated.
A faulty wheel speed sensor (if it's reading low, not just flat out bad) could trigger ESP. If steering is not properly centered, ESP can be prematurely activated when turning in one direction.
Old Feb 22, 2013 | 09:28 AM
HBC's Avatar
HBC
Thanks! I was thinking 'vacuum leak'. Didn't think of the oil and will check it. I've run 93, put SeaFoam, changed stations, etc., so I know it's not the actual fuel. I would hate to take it to the dealer...
Old Feb 22, 2013 | 09:43 AM
HBC's Avatar
HBC
I need to have my front end aligned. I 'whacked' a huge rock on the trail and my BAS and ESP lights have been on ever since. The ABS light is the one that has only recently been coming on when the power fails. Thanks!
Old Feb 22, 2013 | 05:26 PM
The last post helped with the additional info. You just need to have it aligned and steering wheel straigtened. Your electronics thinks that your having wheel sping. This happened to me when my steering wheel was no longer straight after wheeling. I'm betting this is what it is.
