Power steering fluid?
Old Jul 12, 2010 | 07:44 AM
Hellbound13's Avatar
Default Power steering fluid?
What kind does the JK use? Is it ATF 4. If so can I just get any ATF 4?
Old Jul 12, 2010 | 01:57 PM
ronjenx's Avatar
Yes, any ATF+4® will work.
Old Jul 12, 2010 | 04:36 PM
Thanks. Will I need an alignment after swapping boxes?
Old Jul 12, 2010 | 04:39 PM
rinkishJK's Avatar
Default Re: Power steering fluid?
U will only have to center wheel. Toe and caster r not affected. Was it a hard job hellbound!??
Sent from my Droid
Old Jul 12, 2010 | 05:10 PM
Sent from my Droid
Dunno haven't done it yet. Will let ya know tomorrow!
Also is the pitman arm keyed or do I have to pay attention to where it mounts on the splines of the sector shaft?
Old Jul 12, 2010 | 06:19 PM
ronjenx's Avatar
The instructions in the service manual are vague. It doesn't say much about indexing the input or output shafts. No mention of a master spline.
Center the steering system
Index both shafts on the old one before anything is disconnected.
Make sure the new box is centered.
See if it looks like the splines line up the same on both boxes.
It probably isn't too critical as long as you get equal turns left and right after all is done.
Old Jul 12, 2010 | 08:52 PM
Thanks!
Old Jul 12, 2010 | 09:05 PM
ronjenx's Avatar
Do you need torque values?
Old Jul 12, 2010 | 09:11 PM
The bolts that hold the box are 80 ft lbs. and the sector shaft nut is 185? Any others?
Old Jul 12, 2010 | 09:30 PM
ronjenx's Avatar
Install a new coupler pinch bolt and tighten to 36 ft. lbs.
Install power steering hoses/tubes to steering gear and tighten to 27 ft. lbs..
