Power window failure due to switch cluster
Hello all - - I just wanted to report a recent problem I experienced with my 2007 JK Sahara. I have about 45,000 miles on it. The driver side power window stopped working on me recently. I was coming home from a camping trip where I had the doors off the Jeep for some wheelin' then put them back on at the camp site for the ride home. At that point I rolled all the windows up. A couple hours down the road I went to roll down the driver side window and... nothing. The other three windows went down/up no problem. I suspected maybe I didn't put the connector on right so I unplugged it and plugged it back in. Nothing.
After some investigation and talking to some of my Chrysler friends I suspected the window switch cluster located in the dashboard. The window switch cluster part number in my Jeep is 04602756AB. At the dealer it costs about $77. Once I put in a new switch cluster the window worked fine. FYI I took some resistance readings on the DEFECTIVE switch cluster / assembly and put it into a chart for reference. It can be found here: http://spreadsheets.google.com/pub?k...rw&output=html I was told that the driver side window pins are pins 13 and 14. Anyway, just wanted to report this out in case others are experiencing similar issues. It was one of those crummy Jeep things but I still love my Jeep!!! |
Here is a more detailed pinout of the window switch module:
Pin Circuit Description 1 - WDO - Master CTRL RR RT UP 2 - WDO - Master CTRL RR RT DN 3 - WDO - Window Down FT Pass 4 - Ground Z910 5 - WDO - PWR Window SW Lock 6 - ILT - Dimming 3 (IP) 7 - WDO - Window Up FT Pass 8 - WDO - Master CTRL RR LT Up 9 - WDO - Master CTRL RR LT Down 10 - No connection 11 - No connection 12 - Power - IGN_RA - F30 13 - WDO - Window Down FT Driver 14 - WDO - Window Up FT Driver |
Bringing this thread back from the grave.
With what you have gone over on this switch module. it seems possible i could replace my window control with rocker switches. |
Originally Posted by john_w
(Post 1424400)
Originally Posted by The_Yeti
(Post 2046814)
JK-Ford.
https://www.jk-forum.com/forums/show...45#post2047345 I have a thread where i am working on this project and trying to get information. I think i have a solution if you wouldnt mind telling me what you think |
