Problem with starting and maintaining idle
My brother had a similar issue with his 07 after hitting a puddle at speed. Check your plugs to see if there is unburnt fuel. His problem was cold water hit the hot spark plug distributor. I'm sure that's not the technical name but its black and all the plug wires go into it. The cold water caused it to crack and one of the plugs then stopped firing. Wad fixed under power train warranty. It's an easy swap if dealer won't fix it. Not sure on the parts price. Might try pulling it and seeing if its cracked.
