Pulling Right
Old Mar 26, 2012 | 01:49 PM
smokediver's Avatar
Default Pulling Right
I was out today when my 2008 JKU with about 60k miles on it started pulling hard right and the ESP/BAS light came on. I wasn't too far from the house when it started so I drove home. When I pulled in the garage it smelled like something was hot, and after checking it out my front right wheel was hot as hell. I guess that brake was locked up. Has anyone had this or know anything about what may be going on. Any insight will be appreciated.
Old Mar 26, 2012 | 01:54 PM
blue project's Avatar
Your brake caliper grabed the brake and wouldnt let go. In other words it collasped. This in becoming a common JK problem. You need to replace the caliper, possibly the rotor from the pads glazing it over.
Old Mar 26, 2012 | 02:00 PM
smokediver's Avatar
Would this also be the cause of the ESP/BAS light coming on?
Old Mar 26, 2012 | 02:05 PM
I would guess yes. The vehicle isnt acting "normal" so that is probly triggering the ESP. ESP being stability/traction control, it tends be a bit touchy. Once your replace the caliper unplug the negative battery terminal, it should reset the computer. At least thats the way most vehicles are.
Old Mar 26, 2012 | 02:10 PM
smokediver's Avatar
I'll give it a shot, thanks for the help
Old Mar 26, 2012 | 04:19 PM
Let me know how it all works out. A friend of mine had his caliper collapse on the highway, that and my blazer had a similar issue. Been there, done with that!
Old Mar 26, 2012 | 04:29 PM
smokediver's Avatar
Will do. I had a pickup that the brake line collapsed, pretty easy fix. I just wonder about the ESP/BAS, it's not just the skid mark light thats on it's also the ESP/BAS warning light. I drove it a couple of miles to get to work tonight and the light was still on but the brakes felt fine
Old Apr 9, 2012 | 09:05 AM
smokediver's Avatar
My right brake started sticking again yesterday so I went ahead and replaced the caliper. Seems to have fixed the problem but I guess time will tell. Thanks for the help
