question: adding coolant?
Old Mar 29, 2011 | 11:17 AM
mabar's Avatar
Originally Posted by funtimes
so I went and added prestone 50/50 blend to mine....It says right on the jug "mixes with any color antifreeze and any make and model vehicle" I'm assuming this is ok...right?
Nope, DO NOT use any antifreeze that is "universal-type." Mixing Prestone "universal" with factory Mopar or Zerex G-05 HOAT coolant may not hurt anything (I'm not sure), but the HOAT coolant is a better coolant. Mopar is available at Jeep dealers, and Zerex G-05 is available at many auto parts stores.
Only MOPAR brand or Zerex G-05 coolant for a Jeep, built after about 2000 or 2001.
http://www.valvoline.com/products/br.../antifreeze/42
Maybe it is now time to drain and flush your system, since you added Prestone. If you only added a little, it probably won't matter.
Flush procedures for a TJ here. JK will be similar.
http://www.tmar.net/coolant_flush.htm
Mabar
Old Mar 30, 2011 | 06:53 AM
cybersymes's Avatar
Originally Posted by mabar
I hope there is water in yours! Proper antifreeze/water mix is important, and is usually a 50/50 mix of antifreeze and distilled water = approximately 34 degrees below zero protection, plus summer boil-over protection.
You can actually go up to 70% antifreeze & 30% water, for maximum freeze protection, but not more.
If you go over 70% antifreeze, your freeze protection actually gets worse! 100% antifreeze has poor freeze protection.
The proper antifreeze for your Jeep is ONLY Mopar brand, or Zerex G-05 antifreeze, which is a HOAT type coolant.
Proper coolant/water ratios are on the back of the jug. DO NOT use any "universal type" antifreeze.
Use caution when purchasing antifreeze. Some jugs are pre-mixed with 50/50 antifreeze and water. DO NOT add water to those. Other jugs are 100% antifreeze - then mix accordingly.
Mabar
ratz...i was told at the stealers to just add coolant...
looks like i'm going to flush and replace with mopar...
seems odd that they would tell me to use straight fluid...
maybe it is pre-mixed...i'll have to check it out...
many thanks for the info...
Old Mar 30, 2011 | 09:44 AM
Jiblet's Avatar
if you added a quart (liter) or less you have no worries.
Old Mar 30, 2011 | 10:52 AM
cybersymes's Avatar
sweet...added a liter...
need to check it out for future reference tho...
thanks for the heads up ...
Old Mar 30, 2011 | 12:05 PM
Jiblet's Avatar
next year or so when you change all the coolant, just be sure to use the HOAT from mopar or zerex G-05
its supposed to last 5 years; I'll be changing mine after 4.
sláinte mhaith
Old Mar 31, 2011 | 01:15 AM
cybersymes's Avatar
sláinte mhaith
checked my GM product...yep...needs to be diluted half and half...
also checked my motorcycle coolant...i have a v-max...
it's already diluted...so you just add it and no water...
that's how i got confused i reckon...
thanks again... slainte ...
