Questions about the JK stock springs
Old Mar 9, 2012 | 07:28 AM
dan3jeeps's Avatar
Default Questions about the JK stock springs
I am about 1/3 of the way through the thead "Let's solve the stock springs question" and have a couple quick questions.
Will springs from a '12 model fit previous years?
What is the part number of spring that apparently has the highest spring rate so far as figured by this other thread? Fronts and rears, please.
I have an 07 with apparently the LOWEST spring rates. My 2 door JK has a 2.5" BB on an I am wanting to experiment with the higher spring rate stock springs and all the heavy aftermarket stuff I have mounted an keeping the jeep sitting where it was to begin with (pre winch and heavy bumpers.
The heavy stock spring rate springs sound like they might give me what I am after.
I have a couple jeep dealers in town and I can easily run down the springs I need as long as I have the right part numbers for the springs. Be a fun weekend experiment.
Thanks!
Old Mar 9, 2012 | 08:45 AM
OH9JK's Avatar
JK-Forum Ambassador
The last two numbers is what you are looking for 19/60 are the highest.
All model years 07-12 will interchange.
52126519AB FRONT COIL SPRING
68004260AA REAR COIL SPRING
Old Mar 9, 2012 | 09:16 AM
dan3jeeps's Avatar
Some seem to have installed the same front springs (for example 19/19 instead of the factory 17/18 set up). Any problem with doing this or would it be better to take the factory's lead in the consecutive numbered front springs?
Seems as if aftermarket lifts don't do this. Am I correct?
Old Mar 9, 2012 | 10:09 AM
OH9JK's Avatar
JK-Forum Ambassador
The drunk monkeys at the factory seem to grab whatever is handy
Definitely use the same spring rate on each side.
Old Mar 9, 2012 | 11:39 AM
4x4chick's Avatar
Jeep like to put a higher number spring on the gas tank side for the added weight. You don't need that. Same numbers will do if you go 18 and above. 17 and below might make a difference as those are normally the ones that don't have the same number on both sides.
Old Mar 9, 2012 | 01:01 PM
DirtyDi's Avatar
Didn't hurt mine using the 19/60's.
