Sponsored by:
Sponsored by: DashLynx
Recommendation on new tires, spacers and budget lift
Old 07-08-2016, 12:07 PM
shamanite's Avatar
Default Recommendation on new tires, spacers and budget lift
OK, looking to replace the tires on my stock 2012 Sahara Unlimited. Here is what I want to achieve:
-Biggest diameter tires I can fit on my stock 18" rims.
-More aggressive looking.
-Good in the snow (northeast Ohio snow-belt!!)
-Wider stance so they stick out past the stock fenders a bit.
Should I just plan on a budget lift (and which one?). Will I need wheel spacers, and what thickness?
Thanks all!
Old 07-08-2016, 01:54 PM
stangmike1's Avatar
Originally Posted by shamanite
OK, looking to replace the tires on my stock 2012 Sahara Unlimited. Here is what I want to achieve: -Biggest diameter tires I can fit on my stock 18" rims. -More aggressive looking. -Good in the snow (northeast Ohio snow-belt!!) -Wider stance so they stick out past the stock fenders a bit. Should I just plan on a budget lift (and which one?). Will I need wheel spacers, and what thickness? Thanks all!
Look at the Toyo RTs they are great and come in 12.5 and 13.5 withs and are the only tire of its type with a 45k warranty
Old 07-08-2016, 02:39 PM
saharaharry's Avatar
Default Tires
You could try 275x65R18 GoodYear Duratracs. Great, aggressive tire. Been running them for a while. You won't need spacers, aboost or even a leveling kit. Also you do not need "e" rated. So they are reasonable. Good Luck!
Old 07-09-2016, 08:35 AM
jbenmc's Avatar
I had 295/65/18 duratracs (33x12) on a stock jku using 18x9 wheels with a -12 offset. They would clear just fine on stock wheels with a set a spidertrax wheel spacers. 30,000 miles on mine and about 13/32s tread remaining.
Old 07-09-2016, 09:48 PM
BFGMallTerrains's Avatar
Thanks all!
Go 315/70/17 Duratracs -very aggressive looking, new wheels with proper backspacing (not much more than spacers), Craigslist your stock wheels, Teraflex 1.5" leveling kit ( assuming you don't boulder crawl regularly), and regear to 4.56 or 4.10. You'll get the look you want. Also, seems 18" tires are more expensive than 17". Someday you, too will regret not going bigger when you had to replace tires anyway.
Old 07-11-2016, 04:34 PM
shamanite's Avatar
What thickness wheel spacers did you go with?
Old 07-11-2016, 08:48 PM
bconrad5150's Avatar
Duratracs. I am on my second set. The are quiet, aggressive, and will last a long time.
Old 07-11-2016, 09:11 PM
kmrtnsn's Avatar
I'd take a good look at the new Falken A/TW3s.
Old 07-13-2016, 09:56 PM
jkdoppler's Avatar
Heard good compliments with their new A/T W3 and good as cheaper alternative.
Personally, I would go with Duratrac. I think they are good mud and winter tires with the aggressive looks you are wanting. Cousin in MI got 40k miles on there and still got plenty of tire life.
Old 07-14-2016, 10:20 PM
I was pushing 70k on my duratracs. I only put on a new set for a trip on the Rubicon. Could have squeezed a bit more out of them.
Quick Reply: Recommendation on new tires, spacers and budget lift
