Sponsored by:
Sponsored by: DashLynx
Radiator Leaking
Old 05-02-2017, 04:03 PM
karls10jk's Avatar
Originally Posted by Northridge4x4
We run Mishimoto's in several of our Jeeps. Regardless of radiator choice, you should check out the Evans Waterless Coolant. Very neat product with some helpful attributes. One big thing, as that is runs at basically zero pressure, so even as it heats up it puts a lot less stress on hoses, joints, welds, etc. It will last the life of the vehicle!
https://www.northridge4x4.com/search?q=evans+coolant
So with that coolant, what's the flush procedure to get all of the HOAT out? The factory manual says not to use any chemical cleaners. I've been intrigued by the Evan's for a while now.
Old 05-02-2017, 04:12 PM
Sponsoring Vendor
Northridge4x4's Avatar
The biggest issue really is with mixing coolant, not changing coolant. combining OAT/HOAT makes bad things happen. You do need to buy the full capacity of your system in the Evans flush, it basically absorbs all of the water/coolant out of the system. Then you fill the system and pretty much forget about it.
Quick Reply: Radiator Leaking
