rain gutter???
anyone come up with something to keep the water from rolling off the top and coming in when you open the door ...its right at the seam of freedom top and winshiel ...it just pours onto the floor mat...
I thought I was the only one with the problem (4 door-soft top), since I never saw any threads on it...then my hunting partner got a Sahara Unlimited with a Freedom Top, and his is worse...it's just that the roof is much narrower than the base at the doors, and that water in the gutter has to run somewhere...HC has a good idea about shaking it...and I also found that the water will form a puddle above the rear doors, and if you slam the doors hard, it will pour down and dump into your rear windows, if they are open...HC's idea also helps for this.
ive had same issue.....even worse, when doors are off and driving in rain, the water comes in through the soundbar (curves around somehow) and goes to teh center of the vehicle and rains down on the inside, its nice haha....i guess thats too be expected while driving in rain though
im thinking of trying to make a small deflector and glue it up there maybe out of transparency plastic used on overhead projectors or maybe beer can aluminum....oh wait i don't have any ...hmmmm need to empty a beer can
...kinda like patching a roof leak ...you only need to do it when it rains but you don't wanna work on it IN tha rain
I have no idea about a fix for the hardtops as i dont have one, but...
I know the top-props used to work pretty well on the older models to keep the water from pooling on the soft top. It is just a fancy plastic bow that keeps a curve in the top to keep it from puddling and dumping on you when you first open the door.
I seriously considered it, but my top goes up and down frequently, and i thought it would look hokey with the top down, and i have no way to store it if i remove it unless i left it at home, which would pretty much defeat the purpose. So i just give the thing a hefty shake before i get in.
