JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Stock JK Tech (https://www.jk-forum.com/forums/stock-jk-tech-12/)
-   -   Rattle (https://www.jk-forum.com/forums/stock-jk-tech-12/rattle-264005/)
Ray-Ray82 Feb 12, 2013 11:37 AM
Rattle
Hello i just traded my toyota FJ for a 2010 Jeep wrangler rubicon. I noticed today that when i go to pass a car and floor it i hear this rattle i am not sure if it is normal or not it seems like there is something loose but i don't see anything any info would be grateful thanks
Winged Feb 12, 2013 11:50 AM
A bit more info needed. At times it can be the heat shields from the cross over pipe or the one next to the headers. depending on what the person who owned you jeep before you it might be your drive shafts.
Ray-Ray82 Feb 12, 2013 12:13 PM
It sounds like it is coming from the passenger side and only does it when the engine is above 5000 rpm even if i am in park i am thinking it is a shield i bought from a jeep dealership
Winged Feb 12, 2013 01:23 PM
chECK UNDER THE HOOD FOR MISSING PAINT ECT. ( OR IN MY CASE MISSING MUD/DIRT) WITHER WAY IF ITS NOT ACTING STUPID THEN SCREW IT. MINE DOES IT ALL THE TIME AND I CANT FIND IT, MAINLY BECAUSE IM LAZY, BUT ITS NOT HURTING ANYTHING SO I REALLY DIDNT CARE
zombie4x4 Feb 13, 2013 03:47 AM
is it a rattling or more like a pinging noise that could be coming from the engine?
KhakiStinger Feb 13, 2013 03:55 AM
If it sounds like it is right at the firewall it could be the heater tubes behind the dash rattling against each other. There is threads in this. People have fixed it with a piece of heater hose placed between the two tubes so they don't vibrate against each other.
chevynolonger Feb 13, 2013 04:44 AM
1 Attachment(s)
It's your heat shield of your y pipe. they are known for the welds braking off. You can either weld it back on to your exhaust, pry it off, or clamp it back into place. if your look at the picture I posted it would be where I circled.
Ryan0260 Feb 13, 2013 07:27 AM
I would check all the heat shields. I had one that rattled pretty bad, but was able to pry it out and stop it.
1904JK Feb 13, 2013 08:45 AM
Why u reving you engine over 5000rpms anyway?
Mason2314 Feb 13, 2013 05:53 PM
The first thing I do every morning is check the rev limiter in the Jeep. There's only one way to know...
© 2026 MH Sub I, LLC dba Internet Brands
