Sponsored by:
Sponsored by: DashLynx
Rattling sound on acceleration...
Old 04-16-2015, 11:53 AM
Mark Doiron's Avatar
A bad catalytic converter (internally breaking) can also cause a rattling sound.
Old 04-16-2015, 02:47 PM
Twinkydog's Avatar
You might also check the skid tab that goes under your crossover pipe. I keep bending mine up on my '11 until it just contacts the pipe.
Old 04-16-2015, 03:33 PM
DunnyBunny's Avatar
Use a hose clamp. Exact same place mine was. Hose clamp will fix it.
Old 04-16-2015, 05:21 PM
zstairlessone's Avatar
I have two clamps one on each end on my 3.8, cheaper and easier than tacking which would fail again anyway. Almost 20,000 miles with the repair and going strong.
Old 04-17-2015, 09:43 PM
CO Jeeper's Avatar
Originally Posted by smittycm
This. There are a couple heat shields attached to the passenger side y-pipe at the first couple bends after exiting the cat. I would check one of the welds on those first.
x3 that it could be a heat shield.
My rattle came from the one near the muffler and seemed worse on colder days
The rattle is pretty much gone now after I bent some of it away from the exhaust (pretty easy to bend).
Old 04-20-2015, 11:29 AM
slednecks13's Avatar
im having the same issue. i have a 07 jku just hit 80k miles. i brought it in when a check engine light came on and hes telling me its the catalytic converter. around 1500 rpm's when im trying to go a little faster it rattles then goes away when it kicks in and goes to 2500 3000 rpms. im going to bring it to a dealership to see what they say first.
Old 04-20-2015, 11:39 AM
tribulation138's Avatar
Is the catalytic converter where the o2 sensors plug in?
Old 04-20-2015, 12:28 PM
Yes. On a 3.8 there are four catalytic converters. Two in each side of the exhaust before the Y-pipe. The entire assembly is what is replaced--collector from each exhaust manifold to the Y-pipe, including all four cats.
Quick Reply: Rattling sound on acceleration...
