Rear axle squeak
Old Sep 13, 2019 | 12:26 PM
4wheels4life's Avatar
Default Rear axle squeak
Has anybody ever experienced a seal that squeaks on the rear axle? I thought it was my rear brake squeaking so I took a look at it and even replaced my brake pads as they were getting time to do it. but when I checked further to see what was squeaking, I narrowed it down to the rear outer seal. Nothing is leaking but just seems odd. When the radio is down and I am next to something you can hear it faintly. So I always make sure the radio is up far enough, can't hear don't have a problem, right? I have never heard of this before have any of you?
Old Sep 14, 2019 | 03:50 AM
LC Boyer's Avatar
Vet Army
Sounds like an axel bearing
Old Sep 14, 2019 | 04:27 AM
Hmm. I didn't think of that. I had a leaking seal on the other side a couple years ago and replaced that seal and bearing. This bearing does have 148,000 miles on it. Might not be a bad idea to replace now then later.
Old Sep 16, 2019 | 06:21 AM
smittycm's Avatar
Veteran: Marine Corp
You sure it's not a bent axle shaft? I had a squeak back there and it ended up being a bent flange. Couldn't tell until I jacked both rear tires up, popped the tire off on the side that was squeaking, and threw it in gear to see it as it was rotating.
Old Sep 16, 2019 | 12:09 PM
I don't think so. I thought that at first and did that but did not see any movement. May be worth rechecking though.
