Rear blowout - wheel well plastic
Old Feb 11, 2010 | 06:22 AM
Canipe's Avatar
Default Rear blowout - wheel well plastic
I had a blowout on my right rear of my JK 4 door the other day. Apparently a piece of metal or a bolt punctured the tire and then flew up and put a fist sized hole in the black plastic wheel well liner.
I've looked on line and can't find this part. It looks like it should just be an easy fix to unscrew and put in a new one. Anyone know where I can find this part?
Thanks,
Barry
Old Feb 11, 2010 | 06:25 AM
07JKX's Avatar
sounds like a trip to dealer for that one.
Old Feb 11, 2010 | 07:40 AM
Matt08jk's Avatar
OEM Catalog - 2008 Jeep Wrangler Unlimited
Item Number: 55157126AD, SHIELD SPLASH - REAR RIGHT
MSRP: $66.35
You should be able to get this for around $40 online or with full discount at your local retailer.
btw, the rear left is 55157127AD
You can easily replace this yourself. What you will also need is a plastic rivet gun and a pack of plastic rivets and maybe a pack of fender clips. There is another thread somewhere that shows the best place to get these as the dealer charges way too much.
Just Google "JK Aftermarket Fender Clips" and you will find the an online source for these clips.
Old Feb 11, 2010 | 07:48 AM
racer83l's Avatar
Matt, excellent post... im debating buying new splash shields for my JK...there just a bit pricey...
Old Feb 11, 2010 | 09:43 AM
Red's Avatar
Red
Another option is to remove it and coat the metal with the liner or underbody protection of your choice. It is less expensive and looks better than a piece of plastic IMO.
Old Feb 11, 2010 | 10:21 AM
meatsandwich's Avatar
Maybe someone who did the fender trim will post up
I gave one of my rear liners to a local guy that had the same issue.
(The other one got recycled)
Old Feb 12, 2010 | 03:44 AM
Canipe's Avatar
Thanks Matt. Do you guys recommend somewhere online to order it from - any supporters of JK-Forum.com out there?
