Rear brake question...
can someone please tell me why after this
my brakes look like this?!?!?!?!
i just put the lift and 35's and brake lines on total maybe 250 miles... and i know i didn't drive with the parking brake on... so wtf happened? i go play maybe 2 times a month could me being on the brakes at the park do this? i also permanently turn off the traction control with the steering wheel dance...
That's what happens when your brake lines are not bled properly.
You should at least bleed that specific line ... in addition to any other lines that are further from the master cylinder than the caliper from which you removed those pads.
I can almost guarantee it's not a defect in the pad.
Good luck.
You should at least bleed that specific line ... in addition to any other lines that are further from the master cylinder than the caliper from which you removed those pads.I can almost guarantee it's not a defect in the pad.
Good luck.
30 mins to change the pads...
